GeorgeB
I’ve tried several suggested solutions to make the grid boxes the same height.
https://drshernandez.com/test-home-page-with-generateblocks/
None of them have worked. There were two separate solutions telling how to enter Additional CSS in GeneratePress > Appearance > Customize, plus entering a name in GenerateBlocks > Advanced.
I tried entering the Advanced name for various containers and Grids, but nothing worked. Is there an updated standard solution? Thanks!
I’ll put login below in case GP techs need to look around.
Since GB 1.8, you won’t need to use CSS for that anymore.
Select the Grid containers, set height to 100%.
GeorgeB
Thank you, Ying. Done!
