chris190
I want to reduce the overlap of the post headings and content on the hero image on the Explore theme from the library. Where are the settings for this?
Can you add in your GP Premium support key first?
It can be done in the first sidebar widget.
chris190
Done. Although I have realized that the overlay is actually a container on the hero image rather than the beginning of the content post, so I can change the spacing in the element. Unless you have any other thoughts?
Thanks anyway. -
Hi Chris,
The way you described is the way to go.
1. Edit the page hero element, select the container block which contains the heading and post meta, set its margin-bottom to
-50px.2. Edit the content template element, select the very outside container block, set its
margin-topto30px.You can change the value to -60px/40px or -70px/50px, the 20px gap is due to the hero element’s 20px border width.
Hope that works for you 🙂
chris190
Thank you for the suggestion—very helpful.
Glad to hear that 🙂
