Can you please check the featured image shows two times in some posts, like
https://wowrxpharmacy.com/blog/general-health/augmentin-and-alcohol/Regards
The link you shared leads to 404 error, can you check?
This must be the cache issue, can you please check this URL
https://wowrxpharmacy.com/blog/general-health/augmentin-and-alcohol/?v=1241241Regards
there is a hero section at the top of the post that includes the title, post meta and the 1st featured image.
Is that Element a Page Hero?
If so edit that, and in the Elements Settings, check the Disable Featured Image. This will remove the second image.See here for reference:
https://docs.generatepress.com/article/block-element-page-hero/
If I turn on Disable Featured Image, both featured images will be removed.
This issue occurs with new posts onlyRegards
The link you shared above, no longer shows 2 images, did you resolve the issue ?
