feed error
  • Suddenly I can’t see this part. I would appreciate it if you could tell me what the problem is. I’ll give you the login information.
    The /feed is not something we have control over.
    Try disabling plugins to see if a plugin is causing the issue.
    If not, check you htaccess. It’s best to search Google regarding this. Try reaching out to WordPress forums regarding this as well.
  • All right. thank you
  • You’re welcome!
