I changed typography to host locally (to be in accordance with GDPR) however it takes a while before the font changes from default one to the one that is chosen. Is there any method to keep hosting font locally but make them load faster?
You can try preloading the fonts by adding the below HTML to a hook element, set the hook name to
wp_head
.Change the
href
andtype
to the actual ones:<link rel="preload" href="http://example.com/path/to/fonts/local-font1.woff2" as="font" type="font/woff2" crossorigin> <link rel="preload" href="http://example.com/path/to/fonts/local-font2.woff2" as="font" type="font/woff2" crossorigin>
Thank you. Intype should I use a font name, like below?
type=”poppins/woff2″ crossorigin>
no the type should remain as Ying provided. ie.
But … before you do that.
In your Customizer > Additional CSS you have some other @font-face CSS, and ALL those fonts are returning a 404 Not Found error. I don’t think you need that CSS, so remove that so the browser does not waste time trying to load them. -
works well now, thank you very much
Glad to hear that!
