after updating GenerateBlocks and GenerateBlocks Pro, the Font changes in my Backend.
Before the update, I had the same Font as on Frontage. Now it looks weird like in the Screenshot:
https://prnt.sc/iseLkQfOu2CXOn the Frontend, it looks like this, like it should
https://prnt.sc/SuatJhG_JGp2The Font is local.
And this despite the fact that I have the following snippet active, to Show local fonts in WP block editor:
add_filter( 'block_editor_settings_all', function( $editor_settings ) { $css = wp_get_custom_css_post()->post_content; $editor_settings['styles'][] = array( 'css' => $css ); return $editor_settings; } );
If you open the editor, and Right Click > Inspect the editor window to open the Browser developers tools.
In the Console tab are there any Errors or Warnings ? -
No, there are no errors.
There are these 3 Warnings:
block-editor.min.js?ver=f192218ec9fd5b103f38:26 wp.blockEditor.transformStyles Failed to transform CSS. <css input>:109:15: Missed semicolon
107 | /* placeholder focus text style */
108 | .fluentform .frm-fluent-form .ff-el-form-control:focus::placeholder {
> 109 | color: color: var(–contrast-3);
110 | }
111 |
(anonym) @ block-editor.min.js?ver=f192218ec9fd5b103f38:26
deprecated.min.js?ver=e1f84915c5e8ae38964c:2 select( ‘core/edit-site’ ).__experimentalGetPreviewDeviceType is deprecated since version 6.5 and will be removed in version 6.7. Please use select( ‘core/editor’ ).getDeviceType instead.
i @ deprecated.min.js?ver=e1f84915c5e8ae38964c:2
Knoten kann auf der aktuellen Seite nicht gefunden werden. -
you have an error in your CSS.
Under the/* placeholder focus text style */
Look for the line:color: color: var(–contrast-3);
And replace that with:color: var(–contrast-3);
That will fix the error and the WP will happily load it in the editor.
Hi David,
that did the trick. Now it is like before, Thanks.
Just to cover:
The issue comes from the WordPress 6.5 update
It changes the way it handles CSS being injected in to the editor.
And its really intolerant of any CSS mistakes and simply rejects all the CSS if there is a mistake.Glad to be of help!
