Hello everyone.
I’m contacting you again because I have a problem with the footer. The original footer was green, and I’ve changed it to a gray one. When I update it, it doesn’t change and still shows up green (also, it doesn’t display properly).
Can you help me?
Thanks!!
Rita
Hi Rita,
It sounds like a cache issue, make sure you cleared cache after changes are made.
If clearing cache doesn’t work, try disable your cache plugins and go to dashboard > Generateblocks > settings, click the
regenerate CSS
button.Let me know if this helps!
Hi Ying,
No, It doesn’t work.
Sorry, Ying. It’s fixed now. I forgot to deactivate one of the caches. It’s working fine now. Should I activate the cache plugin now?
Yes, you can activate the cache plugin now 🙂
Thanks, Ying!!
Ying, I’m having the same issue again. On the homepage, the footer is green, and on the posts, it’s grey. I had to disable the cache in W3 Total Cache that minimizes CSS, JS, and HTML. If I enable it, the footer turns green.
That means the cache CSS is added by the cache plugin again.
Can you make sure all cache is cleared? If so and the issue is still happening, I would recommend try reaching out to the cache plugin’s support to tweak your cache settings.
Ok, Ying. Thanks again!!!
Best regards
Rita
You are welcome Rita!
