smirandac1978
Hello good night, how are you?
I would like to ask for your help.
I have a problem every time I want to create a new page using Elementor and I have GeneratePress as a template and using a custom footer as GP Element.I don’t know why but in the Elementor editor the footer looks distorted, it loses the styles and the code breaks.
If I publish the page and see it in production, it looks just as bad.However, if I make a page with the Guttenberg editor, I have no problems.
What could be the problem?
Versions:
GeneratePress: 3.4.0
GP Premium: 2.4.0
Elementor: 3.21.3I will appreciate your help.
Thank you.
I’ll give you a screenshot of what the footer looks like with the problems.
smirandac1978
This is a screenshot with correct footer content.
https://imgur.com/a/0XHJwsc -
Can I see the issue on your site ?
smirandac1978
Hi
this is a link with a page with the footer problem. -
Go to Dashboard > Generate Blocks -> Settings and change the CSS PRINT METHOD to Inline Embedding.
Then clear any caches on the site.
Let me know -
smirandac1978
Hi, I follow the indications, but the problem is still there.
Can you confirm if you’ve cleared the page cache? It seems like the footer on that page is still loading an incorrect stylesheet.
smirandac1978
yes cache cleared. I also tried viewing the page in another clean browser and the same problem continues. -
Aah, its not the GenerateBlocks styles that are missing, those are ALL WP Core blocks.
And i can see that it is not loading this stylesheet on that page:/css/dist/block-library/style.min.css?ver=6.5.2
Other users have reported the same issue on Elementor built pages.
Speak to Elementor support to see if they can shed some light on the cause. -
smirandac1978
Hi, where can I see other users reports?
I can’t find a link on Elementor Website. -
You need to do some Google search.
However, reach out to Elementor support should be the most efficient way.
