Generate Blocks
  • How do I use the new pattern style, I use to be able to just copy it and put it in…now that doesnt work. I also dont see the same patterns in the WP block builder…
    What you’re seeing is the new pattern library introduced since GB 1.9 and GB Pro 1.7. If you want to access the old pattern library, you can do so here: https://generateblocks.com/legacy-library
