Hi support team,
my question is:
Please let me know if the Gutenberg Blocks provided by generateblocks pro are compatible with WPML in 2024.Technical details:
I’m planning a new multilanguage website with WPML:I’m using the theme: generatepress premium
– Ok, it is compatible as stated here:
https://wpml.org/theme/generatepress/And the gutenberg Blocks from: generateblocks pro
– No statement on WPML-Website foundObstacles I’d like to avoid:
– Custom XML-configuration files for WPML like here:
https://wpml.org/forums/topic/cant-translate-generateblocks-dynamic-text/Thank you very much
Love your productsCheers
Uwe -
The GB plugin is a block plugin, it’s used to create content, I don’t see why it would have compatible issue with a language plugin 🙂
Hi Ying,
TLDR:
As far as I know, it goes like this, please correct me if I’m wrong:
– The WPML-Plugin needs information, from which parts of the HTML generated by any Gutenberg plugin it can read and replace text.
– If this is defined for WPML for the GenerateBlocks Gutenbergblocks, everything will work fine.The long story:
I year ago, I had this case with another gutenberg plugin, none of yours:
– WPML-Plugin for multilang support in WP
– Translation of content by external human translation agency, using the WPML-API
– WordPress site with Astra Theme
– A Gutenberg-Plugin for a timelineProblem was:
– Text in the timeline plugin wasn’t translated by the WPML-APISolution was:
– Adding XML-Config to the WPML-Settings
– So WPML-Plugin would know, from which parts of the HTML generated by the Gutenberg timeline plugin it would have to read and replace text.
– The XML-Configs contains IDs about HTML contents like header, description, yearThus my question about compatability.
Please let me know your take on this.Thank you
UweRelated:
From 2024, About GB Headline Block
https://wpml.org/forums/topic/cant-translate-generateblocks-dynamic-text/#post-15412368From 2020:
https://generatepress.com/forums/topic/generateblocks-heading-block-and-wpml/ -
the GB blocks should just work with WPML
The reason being is that the content is saved in your post content. NOT in the block data.From 2020:
https://generatepress.com/forums/topic/generateblocks-heading-block-and-wpml/#post-1270960
This still applies.From 2024:
that user is using a GeneratePress Element and the GP Dynamic Data options to add Before and After text. And that requires separate treatment in WPML to handle the before/after text translation.
