Genesis Blocks formatting messing up
  • I’m using genesis blocks and the formatting keeps messing up, sticks to the right or images vanish. I left one of the pre made sections on my page below so you could see how the formatting is incorrect and slid all the way far right.
    I found this online tot try on the support forum:
    Can you try changing Dashboard > Settings > GenerateBlocks –> CSS Print Method to Inline.
    I tried this above and it didn’t fix it.
    This:
    Only applies to GenerateBlocks.
    Genesis Blocks is a different plugin, you would need to check with that plugin support if you’re having issues.
