twi_websites
I’m loading some editor styles to help the block editor reflect our front end design. One thing our front end CSS interacts with is the content container setting (Default, Full Width, or Contained). So I’d like to conditionally load specific editor CSS in order to adjust things appropriately for the current setting. I have two questions along these lines.
- I found the
_generate-full-width-content
meta key that contains the per-post setting for this. Is accessing that meta key directly a relatively future-safe way to do it, or is there a better way (in case the meta key name ever changes, etc.)? - If a layout is being applied so that the meta key is being overwritten, how would I detect that in PHP code and get the correct value?
- I found the
May I know what your final goal is regarding the editor style?
twi_websites
The goal is to get the editor to reflect the widths used for the different Content Container settings. Since the classes that define those settings in the front end are not output in the editor (since it’s outside the scope of the post HTML), I’m using editor styles to add the max-width to the
editor-styles-wrapper
class. That seems to do the trick, but I can only set one width for every setting unless I can tell the difference between the different Content Container settings in the editor. -
The content container setting should reflect in the editor by default, if you are not seeing it, then there is an issue on your site.
Check this screenshots of my editor during the content container change:https://app.screencast.com/wjhV2t8AXSmUU
Can you try disabling all plugins and custom functions to test?
twi_websites
Yes, the default GP styles do. But I added some custom CSS to tweak the container settings. I’m just looking for a way to get those tweaks into the editor to better match the front end. Does that help explain it better?
I still don’t understand what you are trying to do, what is the CSS you added?
If you want to add CSS to the editor, you can try something like this, example for post’s editor:
wp_add_inline_style( 'wp-block-library', '.post-type-post .editor-styles-wrapper { max-width: 800px !important; margin-left: auto; margin-right: auto; }' );
twi_websites
For example, tweaking the “Contained” width:
.contained-content .entry-content { max-width: var(--contained-width); }
Trying to translate something like that to the editor so it only takes effect with the “Contained” setting.
The editor does not have either class in your CSS.
Do you want to adjust the
if the page’s content container being set to contained?By the way, do you know that you can set specific contained width via a layout element?
twi_websites
Correct. I’m trying to do something equivalent in the editor. I can conditionally add CSS to the editor that will do what I’m looking for, but I’d need to know which content container setting is in use by the post/page.
Do you want to adjust the editor-styles-wrapper if the page’s content container being set to contained?
Yes, that is something I’d like to do.
Yes. Though one limitation of that is, it requires the width to be in pixels. We use rem for most things these days. I’m also trying to set things up so that most of the time deviating from the default layout can be done more on a page-by-page basis instead of using the Elements way due to translations. Setting up an Element layout to be used across all the translated versions of a particular page is a rather annoying process. It’s much easier to specify it at the page level in the block editor because that automatically carries over to any translations of that page.
Thanks for your help.
Try this PHP:
wp_add_inline_style( 'wp-block-library', '.block-editor-page:has(option[value="contained"]) .editor-styles-wrapper { max-width: 80rem; }' );
Let me know if this works!
twi_websites
That almost worked. I added
[selected="selected"]
, otherwise it was doing it for every page regardless of selected layout..block-editor-page:has(option[value="contained"][selected="selected"]) .editor-styles-wrapper {...
That’s a nice solution because I can keep the code in the editor CSS file I’m making. Thanks!
That being said, is there a way to make it work when a layout Element is used as well (as of right now it doesn’t because the layout Element overrides the editor option). If we are making an entire post type have a certain container setting, we’d probably use a layout Element (making it post-type-wide doesn’t have the same translation issue of specific pages). Do you have any insight into how GeneratePress finds the layout that applies to a post?
Hum… I don’t think there’s a way to target it.
The
--content-width
is calculated in JS, you should be able to find the JS atgp-premium/src/plugins/block-elements/index.js
, hope that’s helpful! -
twi_websites
Unfortunately, I don’t see a
src
directory included with the plugin package. I’m assumingdist/block-elements.js
is the compiled version of it (which I did stumble upon). But since it’s minified, it’s really hard to read. Although even if I could, I don’t think I’m familiar enough with React to understand how to use what I find. A PHP solution would be more in my realm of knowledge.So maybe there just isn’t a feasible way to do what I’m looking for, which isn’t the end of the world since it just affects the editor. Thanks for your help, though.
The JS path I attached is correct (I double checked), you can find it in GP Premium’s plugin.
Me either, not familiar enough with React 🙁
Sorry couldn’t help more!
twi_websites
