locke85
I’m using the borders of an inner container as a picture frame, which creates a visual effect around the central item of a carrousel.
In the current version I’m using a static positioning (margin based) for the two-part frame.
How would change the settings of the frame-top- and frame-bottom-container in order to position them in the center of the wrapper-container no matter which screen size?
Thanks,
Jan -
tough one, considering if you view the front end, the carousel isn’t center, and that changes depending on the screens size.
first thing to do would be to make sure the carousel always has a centred item.
Then revisit hoe to put the frame into place. -
locke85
You can read my mind, David 😉
That is exactly what I did in the meantime:
responsive:{ 0:{ items:1, stagePadding: 40, margin: 100, center: true, },
I then removed the margin setting and made it work.
Is there any documentation/ tutorial that helps me better understand how to use relative positioning (layout “block”, “inline”, “inline-flex” etc.)?
Thanks,
Jan -
Some info on the position property here:
https://developer.mozilla.org/en-US/docs/Web/CSS/position
Consider you have the container with the
carousel-wrap
class as the parent element to which you want to centre your “frame”. Begin by setting its Layout > Position to Relative, or use this CSS to do the same:.carousel-wrap { position: relative; }
You can the add a container inside your carousel-wrap and give it a class of
carousel-frame
This frame you could position absolutely in the center with this CSS:.carousel-frame { position: absolute: left: 50%; top: 50%; transform: translate3d(-50%, -50%, 0); pointer-events: none; }
OR Alternatively you could position the carousel-frame to cover the entire carousel-wrap:
.carousel-frame { position: absolute: inset: 0; pointer-events: none; }
Then you can add blocks inside the carousel-frame, and set the carousel-frame layout to flex and justify / align those blocks to the center.
