Since the 6.5 WordPress update my post editor background has turned gray instead of the usual white. What might be causing that?
I disabled all plugins and it seems to be caused by the theme.Thanks!
the Theme loads editor styles to try and match the editor to the front end.
The Editor background color should match the color you set in the Customizer > Colors > Content.
If that color is empty, then it will fallback and use the Customizer > Colors > Body.But this has been the case since way back in WP 5. And we have not changed that.
Can you first check those colors in the customizer ?
If need be, share a temporary admin login to the site in the private info below and ill take a closer look
This solved it!
Glad to hear that
