Hi guys,
Is it possible to create a grid inside a content template for ‘case studies’like the screenshot I added. I’d like to fill in the case study as a post and then have generated in the layout I want. The headings will always be the same.
Yes, you can create whatever layout you want for the content template.
Thanks Ying. I understand that but how will the content pull into the same layout as I added in mt screenshot? When I create the post do I need to set it up in the same layout or how can it pull into the content template.
Thanks 🙂
You need to create custom fields for the posts, then use the headline block to pull the data dynamically via post meta > custom_field_slug.
You can use WP’s native custom fields, or use a plugin like ACF.
Ah gotcha! thanks Ying that makes sense.
No Problem 🙂
