gyanitechraviji
h1 heading not showing in google search? site name – gynitechraviji.com gyanitechnews.com
Hi there.
this link
gynitechraviji.com
does not work. The other one does.
Is this only on the homepage ?if it is then i suggest you use the Site Title in your Site Indentity as this will be set as the homepage H1.
gyanitechraviji
gyanitechraviji.com & gyanitechnews.com
I am not talking about homepage. My both website 80% post h1 heading is not showing in google search. Due to this the ctr of blog is down. And the adsense cpc is also very low from last 15 days.Please check & update.
I checked some posts on your sites, and they all have the
H1
entry title that the theme displays.
See here for example:And thats all the theme does with the H1 heading. Nothing more.
I also checked the title tag for that example post:
https://www.gyanitechraviji.com/thinking-effect-in-hindi/
And this is it:
<title>Thinking Effect in hindi हमारे जीवन में सोच का प्रभाव</title>
So it too has a title tag for search engines to use too, But that title tag looks like it has been changed by your SEO plugin.
Your SEO plugin is also adding
LD+JSON
schema which has an Article type that has the same title as your title tag.To summarise:
The Theme is only responsible for adding the H1 Entry Title. And it is doing that correctly.
The Title Tag and LD+JSON are being changed/added by your SEO plugin.If your search results are not showing correctly , i would suggest you speak with the SEO plugin author as its there code that is more likely to affect SERPs rich snippets
