When scrolling down the page, the hamburger menu which is on the left appears to be slightly moving from left to right. I don’t know where should I go to fix this?
1. Remove this CSS:
/* Style for the primary menu within the sticky navigation */ .main-navigation.navigation-stick #primary-menu { position: relative; /* Position relative to its normal position */ right: -28px; /* Move it to the left */ }
2. Change this CSS:
.site-logo { position: absolute; z-index: 10000; left: 50%; transform: translateX(-50%); }
TO:
.navigation-branding,.site-logo { position: absolute; z-index: 10000; left: 50%; transform: translateX(-50%); }
3. Add this CSS:
span.menu-bar-item.slideout-toggle.hide-on-mobile.has-svg-icon a { padding-left: 0; } #sticky-navigation .menu-bar-items { justify-content: flex-end; } #sticky-navigation .inside-navigation.grid-container { max-width:1200px; display: flex; justify-content: space-between; } .main-navigation.navigation-stick #primary-menu { width: fit-content; }
hichb
Hi Ying,
The layout is nearly perfect! However, when I scroll down to view the sticky navigation, I noticed that the hamburger menu is now on the right and the subscribe button on the left. They seem to have switched positions. I have shared the link to the staging site privately for you to review.
in your CSS you have this rule:
#site-navigation .inside-navigation, #site-navigation .inside-navigation .menu-bar-items { flex-direction: row-reverse; gap: 10px; }
Change it to:
nav:is(#site-navigation, #sticky-navigation) .inside-navigation, nav:is(#site-navigation, #sticky-navigation) .inside-navigation .menu-bar-items { flex-direction: row-reverse; gap: 10px; }
hichb
Thank you! Worked!
Glad to hear that
