talentpair
Hello, I am very new to generatepress. I am trying to create a simple header that has my logo and a navigation menu to the right of my logo. I have uploaded my logo but it does not display. Please give me the steps on how to 1. Upload my logo and see it on my header and 2. Have a menu (drop down) that is my primary navigation (it is already set to my primary nav).
Is the logo uploaded in Customizer > Site Identity?
https://docs.generatepress.com/article/adding-header-logo/Let me know 🙂
talentpair
Yes it is!
Can you clear and disable any caching plugin you might be using?
This includes server caching as well.
talentpair
Hmmm I do not think we have any caching plugins! Is there a way to have you login or show you what my screen looks like? I am using a staging environment.
Hmm I can’t see the source code so I do believe there is some sort of caching going on.
Can you disable all plugins except for GP Premium to test?
talentpair
Alright everything has been deactivated!
I see the logo and title now which means that it was definitely a caching issue:
https://www.screencast.com/t/UHHl89R833jUCan you remove the logo image added in the header widget?
talentpair
I did that! It worked now THANK YOU LEO!!!!
No problem 🙂
talentpair
Hi Leo, back again! I deleted the header while in customize and it solved my problem. When I saved, it shows the double logo in my header…I went to widget > header > removed both logos (creating the header widget blank) > update I get this error: “Cannot read properties of undefined (reading ‘map’)” How can I resolve this?
Can you try disabling all plugins except GP Premium? Then update it again?
Let me know how it goes!
talentpair
All plugins are disabled
And?
Can you provide an admin login to your site?
talentpair
Nothing worked, I added the login info, I am on the staging website so please go there.
I don’t see the login info.
Please try again by editing your first post on this topic, and add the info into the private info field. Thanks!
