curata
I’ve setup a header merge to create a transparent header but it only works on desktop. On mobile, the main header remains.Is there a reason it doesn’t display on mobile? An option or something I didn’t select?
Yes, that is the default behavior. We can make the mobile header transparent too with some CSS. Let me know if you want to go this route, and I will provide the necessary CSS.
curata
Yes please, the mobile header needs to be merged as well.
Before that, may I know if you enabled the Mobile Header in the Customizer?
Go to Customizer > Layout > Header, and set the Mobile Header setting at the bottom to
Yes
if you haven’t.This should make the mobile header transparent when merged.
curata
I didn’t have that enabled, now I have. have now but the banner still isn’t merged. The mobile header is white (no idea where that is coming from as white isn’t used anywhere). Sticky on mobile is transparent, whereas i actually want a solid colour (as per other task).
as this is related to the other topic, can we close this topic,
And we can follow up here: -
curata
Yep, sure thing. Details added in other task.
