Joker62
Hello, i created this topic because i’m working on my website, the generatepress is the perfect base with elementor, the thing is yesterday i was doing some design, i saved one of them in elementor modele and when i try to put this modele in another page, i have now the wordpress title of the page which is appearing (the basic one) even if my page is setup i have no other way to disable it, is there an option to disable it i tried one time in the normal wordpress option “disable the title” but i have this error message (pictures link)
Basically when i try to upload a predesign elementor module in another page, the worpress title is appearing and no way to disable it.
Thank you again for your help maxime
Are you planning to disable the title sitewide? If so, try using the Layout Element – Disable Element module.
https://docs.generatepress.com/article/layout-element-overview/#disable-element
Joker62
Hello, thank you for you help,
Yes it disable on all the website but i do from page to page but when i try to do a modification now on one page it comes back, and i have error Json message that it is not possible to save when i try to disable it.
https://docs.generatepress.com/article/content-container/
i will try to disable it site wide but if i do this will it be still readible for SEO or only hidden for the design? thank you again,
maxime -
if you disable the Content Title then GP will remove that HTML from the site, ie. it won’t output the
H1
Entry Title.If you disable the title using that method then you should look to include your H1 in the content of your page
Joker62
Hello, ok thank you for you help, is there any way to keep the H1 but hide it in term of design?
thank you again for your help maxime, i’m still stuck with the Json message error when i try to disable it manually
You can use CSS
display:none;
to hide it, however, Google does not like that as well.
