Headline BLock
  • Hello
    When using Headline BLock, the default margin bottom value was 20, and I want to adjust the top and bottom values. Where can I specify this?
  • Hi James,
    The default bottom margin in GB Headlines follows the bottom margin you have in Appearance > Customize > Typography for p, h1, h2, and h3. Could you try modifying it from there?
  • Can I set the top, not the bottom?
    is it just the GB Headline Block you want to apply this too ? Or all Headings ?
