Afonso Alves
Good morning everything is fine?
I would like to create a webstories tab with a slider on my home page of my website in this genre: https://prnt.sc/qQ4_zWPkNPcj
Can you help me with directions?
One customer previously recommended: https://wordpress.org/plugins/web-stories/ – I’m not sure however if they have a tab/slider feature.
I would suggest asking for recommendations on our Facebook Group as well: https://web.facebook.com/groups/generatepress
Afonso Alves
I already have the plugin, I just wanted to create a container with some web-stories on the home page with generatepress.
Can you guide me with the next steps?
for tabbed and slider content you would need to ask the Plugin developer how to do that.
the only thing we can offer is, a web story is a Post Type. like a Post or a Page, so you can show a list or grid of them using a Query Loop block. But thats all.
Afonso Alves
Good morning, I was able to practically recreate the intended layout: https://prnt.sc/uQrpJnDhBzGz
It turns out that I’m not able to do this specific design: https://prnt.sc/uyhMc70eB-On
I wanted to leave the image inside a box and this box has the webstory cover on top and the text below.
Can you help me with the next steps?
Cool π Edit the Query Loop block
Inside it select the Post Template block and set its Sizing > Height to 100% -
Afonso Alves
I just did this but no change happened.
Homepage link in private information.
Hi Afonso,
Are you referring to moving the Headline to its own Container instead under the image?
If so, could you share admin login credentials?
Afonso Alves
Yes, I wanted to move the text below the image as shown in the example: https://prnt.sc/qQ4_zWPkNPcj
Temporary credentials are in private information.
Here’s an example of what you can try doing: https://share.zight.com/7KunoXYq
Afonso Alves
I applied these changes and it worked π
But now I have another doubt. I’m trying to keep the resolution of the webstorie image this way on mobile so it doesn’t take up so much space in visibility: https://prnt.sc/9t8OC-idEDy8
How can I correct this spacing below and leave a gap between post templates?
Select the Post Template block, and cheeky the Sizing > Min Height , its set to 450px.
Set it to 0 on mobile. -
Afonso Alves
And now how can I bring them closer together?
Screenshot: https://prnt.sc/chBH7YViK5a1
In order to get closer but with a break: https://prnt.sc/K_F0SOhPGUdt
On the same container that you set the Min Height to
0
you can adjust its Spacing > Margin Bottom to a smaller value on mobile -
Afonso Alves
Thanks it worked π
Glad to hear that!
