sargranger
On our CART and CHECKOUT pages, there is a problem with the padding as the top navigation menu (HOME, CONTACT) overlap the content of the cart and checkout pages. Is there some additional CSS we can add to fix this problem? Thank you.
Links below. -
There is a merged header element activated on those pages:
https://docs.generatepress.com/article/transparent-header-and-navigation/Try using the Exclusion rule to exclude the WooCommerce pages where you don’t want the merged header to apply.
Let me know if this helps 🙂
sargranger
I’m not very good with code. What would the string of code be for the exclusion of the merged header? Thanks for pointing us in the right direction.
sargranger
I think we’re all set. I was able to turn off the merged header for the site and that resolved the issue. Thanks again.
Glad to hear 🙂
