Mark Morgan
My hero image is set on desktop and tablet. I’m trying to set a different image on mobile using the advanced tab (and I did this on my other site and it worked perfectly) but for some reason it won’t show the Heading and Paragraph text when I look at it on mobile. It’s just showing the image with no words.
Can’t figure out why it’s not working, especially when followed the same procedure as on my other site. Am I missing something?
Thanks very much!
Mark -
Hi Mark,
Can you link us to the page in question?
Please make sure you always link the page when you open a topic ๐
Mark Morgan
Hi Ying,
Yes, sorry I’ll make sure I always link the site every time.
staging.wherearethosemorgans.com
When I turn the phone horizontal I can see the words appear. But they won’t appear when the phone is vertical.
Mark -
No worries, all good!
Select the content that contains the text, and set its
z-index
to1
,position
torelative
.Let me know if this helps!
Mark Morgan
Hi Ying,
Thanks for the update, tried those 2 things but it didn’t help.
It’s strange because I’ve copied the exact same settings from my other site on which I did the exact same thing.
I’ve cleared the caches, and cleared the cookies etc on my phone to check if it was either of those but it wasn’t.
Any other ideas?
Mark -
I don’t see the z-index and position being set for the container with text, I do see the z-index being set for the parent container which has the background image.
If you are sure the changes are made to the correct container, then try disable your cache plugin or make sure cache is all cleared so I can see the changes ๐
Mark Morgan
Hi Ying,
Thanks so much for clarifying, you were right I had put Z Index 1 in the parent container, not the text container.
Still getting used to how GP works!
Appreciate the help,
Mark -
You are welcome ย ๐
