I have a custom role “lap_manager” based on “editor” that I have enabled the capability “edit_theme_options” to allow access to edit the menus. However this then also enables Themes, Widgets, Customizer and GeneratePress.
I have been able remove Widgets and Themes with the following, can could hide the Customizer with CSS, but can’t work out how to remove GeneratePress.
// Hide Menus from lap_manager role function hide_menu() { if ( current_user_can( 'lap_manager' ) ) { // Hide theme selection page remove_submenu_page( 'themes.php', 'themes.php' ); // Hide widgets page remove_submenu_page( 'themes.php', 'widgets.php' ); // Hide customize page (alternative method) global $submenu; unset($submenu['themes.php'][6]); } } add_action('admin_menu', 'hide_menu'); // Changed hook to 'admin_menu'
Try this:
function hide_menu() { if ( current_user_can( 'lap_manager' ) ) { //hide themes remove_submenu_page( 'themes.php', 'themes.php' ); //hide widgets remove_submenu_page( 'themes.php', 'widgets.php' ); //hide generatepress remove_submenu_page( 'themes.php', 'generate-options' ); //hide Customizer, assuming customizer is the 6th menu global $submenu; foreach ( $submenu['themes.php'] as $key => $item ) { if ( isset( $item[6] ) ) { unset( $submenu['themes.php'][$key] ); break; } } } } add_action( 'admin_menu', 'hide_menu', 999 );
