cruzbeta
I have been trying to fix my website and have the home page look as seen on https://gpsites.co/. How can I do this?
Which template are you referring to?
cruzbeta
So sorry. It’s this one: https://gpsites.co/explore/
If you want to replicate the exact design of the Explore site, the best approach is to import the entire site. This will bring over the customizer settings and all media elements, ensuring a pixel-perfect match.
However, it’s important to note that you should perform this import on a staging site first. While your existing content won’t be replaced, there’s always a chance of errors, so testing on a staging environment is recommended.
Alternatively, if you only need to replicate the layout structure of the Explore site’s homepage, you can follow these steps:
1. Create a new page and name it something like ‘Reference Homepage.’
2. Switch to the Code Editor mode by clicking the three dots at the top right.
3. Paste the HTML markup of the Explore site’s homepage (you can find it in this gist: https://gist.github.com/alvindcaesar/d800666246c733f7652ba25f40318d61).
4. Use this as a reference to build the same layout structure as the Explore site.
Hope that helps!
