usethebitcoin
I created a hook element that will be shown before header and set on the entire website. But I noticed below, after footer, it was duplicated, pls reffer on the image below.
https://i.postimg.cc/SRN8vcyc/Screenshot-15.jpg
https://i.postimg.cc/NfFm88Cc/Screenshot-16.jpgI have cleared all server cache and even browsers. Thank you for helping.
The one below the footer is an iframe, what is HTML you added to the hook element?
https://app.screencast.com/aHePS7D4Jus8n
Let me know π
usethebitcoin
<!– TradingView Widget BEGIN –>
<div class=”tradingview-widget-container”>
<div class=”tradingview-widget-container__widget”></div>
<div class=”tradingview-widget-copyright”><span class=”blue-text”>Track all markets on TradingView</span></div>
<script type=”text/javascript” src=”https://s3.tradingview.com/external-embedding/embed-widget-ticker-tape.js” async>
“symbols”: [
“description”: “BTC”,
“proName”: “BITSTAMP:BTCUSD”
“description”: “ETH”,
“proName”: “COINBASE:ETHUSD”
“description”: “SOLANA”,
“proName”: “COINBASE:SOLUSD”
“description”: “CARDANO”,
“proName”: “BINANCE:ADAUSD”
“description”: “POLKADOT”,
“proName”: “COINBASE:DOTUSD”
“description”: “POLYGON”,
“proName”: “COINBASE:MATICUSD”
“description”: “XRP”,
“proName”: “BITSTAMP:XRPUSD”
“showSymbolLogo”: true,
“isTransparent”: false,
“displayMode”: “regular”,
“colorTheme”: “dark”,
“locale”: “en”
</script>
</div>
<!– TradingView Widget END –> -
It’s the script that is adding the iframe.
Do you have a performance/cache plugin? I think the issue here is one of those plugins is deferring your JS, so it appears after the footer.
I would recommend checking your cache plugin’s settings.
usethebitcoin
Hi Ying,
Actually the js was set to delayed. I tried to set it as deferred it is still the same. -
It’s not something that we can control, unfortunately.
check with the performance plugin’s support on how to solve this issue. I guess some cache hasn’t been cleared.
usethebitcoin
Hi Ying,
This is solve, I just excluded the js of the ticker. Thanks for helping! π
Nice π
