Humanovation
… update just hosed my site, where can I find the previous version?
the changes we made to the theme should not have “hosed” your site.
First thing is to clear any caches whether that be plugins or serverside, to ensure you have no OLD code stuck in the cache.IF the issue persists can you explain the problem and share a link to the site ?
Humanovation
Rolled back to yesterday’s site backup which solved the issue … all caches had been cleared after updating and again after restoring the backup, including cloudflare, server, plugin, and browser. Will try updating theme again now and see if the issue persists. I posted a followup thread detailing the first issue.
Humanovation
Same issue … CSS not working correctly.
Humanovation
Can you point me to a link where I can download the previous version of the GP theme? I don’t want to roll back the site again and lose the work I’ve done all day …
You can follow this URL to download 3.3.1
https://downloads.wordpress.org/theme/generatepress.3.3.1.zip
But, if i can see the site then i can take a look as to why the “CSS is not working correctly”?
As there is nothing we can add to a theme that stops CSS working so something else is at play here. -
Humanovation
Thank you …
See this thread:
https://generate.support/topic/css-not-working-the-same-after-3-4-update/
