syoung
I would like to use a custom profile image instead of the gravatar for one of my writers, so it shows up in their author page. How do I do that?
Hi Syoung,
For reference, can you provide a link to an author page of your site?
syoung
I added in private information
Here is what I see when I edit the user:
https://www.dropbox.com/s/zhm0ms1zim5rk6x/Screen%20Shot%202023-04-19%20at%209.08.48.png?dl=0
There is no place to change the picture.
You can create a Block Element – Page Hero for that page and add a static image through a GB Image Block.
Reference: https://docs.generatepress.com/article/block-element-page-hero/
syoung
This is great. I didn’t know it was possible.
So now I have followup questions:
1. I still want the image to be dynamic. How do I change a user’s Avatar so it’s not a gravatar?
2. If I want to edit the page hero and also the way the posts are displayed do I need to create a hero element and also a content element? Or do I do this in the same place?
1. You’ll need to add a plugin like ACF and add a new field to users so you can have another image field aside from the one from Gravatar.
2. Yes, that’s one way to do it. Another way is to use a Block Element – Loop Template instead. It depends on your preference.
syoung
Ok, that makes sense. Thank you.
I tried using a page hero and loop template, and can’t figure out how to style the page hero so the author image is right-aligned. I also can’t figure out how to improve the padding on the blog posts because now there is none. Can you help me with that, please?
For the padding, I can see that you’re using a Container Block already on your Loop Template. Just add padding to this Container. Reference: https://docs.generateblocks.com/article/spacing-options-overview/
For the image, I would suggest placing them in a GB Grid Block instead as opposed to the WordPress Block you’re using. That should allow you better options for alignment.
syoung
The Grid block helped. Thanks. However, adding padding to the container doesn’t seem to have an effect.
To clarify, are you using a Block Element Content Template or Loop Template?
Can you provide admin login credentials through the Private Information field so we can take a closer look?
syoung
Loop template. Login credentials provided.
1. For the Avatar, if you’re alraady using ACF and are happy to do that, then great.
Otherwise use this plugin:https://wordpress.org/plugins/simple-local-avatars/
It works seemlessly – by adding a avatar image field in the user profile, that will replace the avatar wherever it is used, including one displayed by GB.
2. The hero – do you have a layout mockup i can see ? I can then explain.
3. Could you raise a separate topic for the padding loop issue.
syoung
I got everything worked out except for the padding loop issue. Thanks. I’ll raise a separate topic.
Glad to hear that!
