LinuxWolf
Hi, I have attached an image. I need help with adding small gap between the number and arrow image. Please look into the picture.
Option A use the flex gap
Select the headline block and in the Layout set the Column Gap.
But this will also add space between the number and the %Option B use some CSS
give the headline a CSS class eg.has-inline-image
Then add this CSS to add margin to theimg
.has-inline-image img { margin-right: 10px; }
Option C use a flex container
This layout:Container Block ---- Image Block ---- Headline Block
set the Container Block Layout to Flex row, and then add some Right Margin to the Image Block
LinuxWolf
Worked thanks
You’re welcome
