A very common layout is a grid of elements that contain other elements with different heights. Let’s say, for example, a pricing table. Usually, the alignment is not perfect. One heading might need only one line, the other might need two lines. I’ve never mastered this and use dirty workarounds like
min-width
etc. A little help would be very appreciated. Let’s take this page as an example (still in development). This is a grid of four columns. The image is no problem, of course, but heading, body text and readmore link do not align properly:HTML and CSS are pretty straightforward:
<div class="grid grid-4 faqs"> <div> <p><img src="" /></p> <p><em><strong>Heading</em></p> <p>Some text ...</p> <p><a href="">Readmore Link</a></p> </div> <div> <p><img src="" /></p> <p><em><strong>Heading</em></p> <p>Some text ...</p> <p><a href="">Readmore Link</a></p> </div> <div> <p><img src="" /></p> <p><em><strong>Heading</em></p> <p>Some text ...</p> <p><a href="">Readmore Link</a></p> </div> <div> <p><img src="" /></p> <p><em><strong>Heading</em></p> <p>Some text ...</p> <p><a href="">Readmore Link</a></p> </div> </div>
.grid { margin: 0 auto; display: grid; gap: 1rem; margin-top: 2em; } @media (min-width: 390px) { .grid-4 { grid-template-columns: repeat(auto-fit, minmax(200px, 1fr)); } }
Is it even possible to align all single elements inside the grid items properly using p tags?
I really tried hard to find an answer, but couldn’t find a solution that addresses this real-life scenario.
Thank you very much in advance for your patience.
you can do this:
.grid > div { display: flex; flex-direction: column; } .grid > div > :last-child { margin-top: auto; }
To cover:
a container with display flex or grid that has no Alignment set ( eg.align-items: centre
) will resolve all child items to have the same height.
So in this case all yourdiv
elements are the same height as the tallestdiv
in that row.You can then make each
div
a display flex column, and that affords you the magic of auto top margin on thediv
last-child which pushes it to the bottom of the container. -
Thanks, David. I appreciate your great support and the explanations a lot. This totally works for the last element. However, there ist still some problem with the heading. With two lines in the heading, the following
p
tags will not align with thep
tags in the other grid items. Would I have to use nesteddivs
here, so that both the heading and the p tag sit in an additionaldiv
? Not sure that I can explain this properly. π If possible I would like to avoid additionaldivs
. This would make editing more difficult for many users (we still use the classic editor). -
Ok, so aligning child elements across the grid row is complicated, as there is is no relation between children of sibling grid items.
The only relation is the height of the divs.The easiest option is to give that element a min-height eg.
.grid > div > p:nth-child(2) { min-height: 6ex; }
Thanks again, David. I’m relieved that even you find this complicated. But I had to look up the
ex
unit. Have never used it before. π This solution it totally fine.Thanks a bunch!
For some reason i seem to always go to the
ex
unit for this kind of thing when it involves the height of text… its kinda fun πGlad to be of help!
A funny postscript: The same problem occured with a list of events. I hate the event calendar plugin from the bottom of my heart, but my customer wants to use it. The source code is so absurdedly bloated that I asked the support to fix the problem for us, since this is a paid plugin! I stated clearly that I don’t want to use static height. This was the proposed solution:
.tribe-events-widget-events-list__events article.tribe-events-widget-events-list__event { height: 170px !important; }
That’s impressive, isn’t it. π
Yep , cannot get more fixed then that lol
