chriswvliew
I am having trouble figuring out how to center this block (the one that starts with “why choose fee-only”) – while still keeping a 1000 px max width. When i put block alignment to center, it removes the max width for some reason and it stretches across the screen.
Have you added the
alignwide
class to the container? If so, remove that class first.Then select the inner container that wraps the heading and text, set the
margin-left
andmargin-right
to auto. -
chriswvliew
hey sorry I tried the margin-left and margin-right suggested here but still can’t get it to work – i don’t see any alignwide class, or know how to remove it exactly if there is one – can you please give some other suggestions or specifics on how to fix this please?
The
alignwide
class needs to be removed for the setting to work.Click on the container, and in the Block settings on the right-hand side, navigate to the Advanced options. Check the Additional CSS Class(es) field to see if the class
alignwide
is added there. -
chriswvliew
There isn’t anything in the Additional CSS Class, I checked all of the containers. So the problem is, there is a layout Element that had full width enabled here, that was built into the Pattern Library I used. I don’t want to remove it because it will break a lot of the page.
Is there any way that I can override that full-width for this container? I’m not sure how the other containers below are able to override this full width enablement.
In that case, try using CSS to override the full-width layout on that container:
.gb-container-6be978b8 { max-width: 1100px !important; margin-left: auto !important; margin-right: auto !important; }
chriswvliew
this worked, thank you
You’re welcome
