I need to create a menu like this website
https://i.imgur.com/4x2eIuD.jpeg
https://i.imgur.com/9fkbR50.jpeg
https://i.imgur.com/qtqD4qZ.jpegAnd this hamburger menu is floating while scrolling.
How can i achieve this for my website?
hmmm…. tricky one, you would need to first enable the Off Canvas Panel for the Mobile menu
https://docs.generatepress.com/article/off-canvas-panel-overview/
Do that first, and then ill take a look at the next requirements
Okay, done, what’s next?
My hamburger menu is not working in mobile, I think my caching plugin is the problem, any help?
Yeah, disable the cache plugin for now, it will be one of the plugins settings breaking it. You can debug later, once we get this done.
Let me know when its disabled.
okay, done. Can you please give a detailed step-by-step guide to this?
1. Add your menu to the Off Canvas.
In Appearance > Menus edit the menu, and include the Off Canvas in its location.2. Add this CSS to create the floating hamburger toggle:
nav#mobile-header { padding-top: 12px; } nav#mobile-header .menu-toggle { width: 60px; height: 60px; border-radius: 100%; padding: 0; position: fixed; right: 12px; top: 12px; z-index: 10000000; font-size: 24px; background-color: var(--accent); color: #fff; } html.slide-opened nav#mobile-header .gp-icon svg:nth-child(1), html:not(.slide-opened) nav#mobile-header .gp-icon svg:nth-child(2) { display: none; } html.slide-opened nav#mobile-header .gp-icon svg:nth-child(2), html:not(.slide-opened) nav#mobile-header .gp-icon svg:nth-child(1) { display: block; } .slideout-navigation.do-overlay .slideout-exit { display: none; }
Do that and then we can look at adding the other content to the Off Canvas.
okay, next step.
Now add all the menu items you want to the off-canvas menu.
For the non-menu items, like title, search and msg, go to appearance > elements, create a block element, add all the content you want, select
inside_slideout_navigation
hook, set the location toentire site
.Once it’s done, we’ll have another look.
Okay done.
I don’t see this:
For the non-menu items, like title, search and msg, go to appearance > elements, create a block element, add all the content you want, select inside_slideout_navigation hook, set the location to entire site.
To cover:
1. go to Appearance > Elements -> Add New –> Block Element
2. in the element settings sidebar set the Hook toinside_slideout_navigation
https://docs.generatepress.com/article/block-element-hook/
3. set the Display Rules > Location to
Entire Site
4. in the element editor
add the blocks you want to display inside the Off Canvas Panel.
E.g GB Image Block for the Logo and a Search Block -
Yep, now add this CSS to remove the them padding from the Off Canvas Menu:
#generate-slideout-menu .inside-navigation { padding: 0; }
Yes, next step please.
The grid columns widths are default to 100% on mobile, set them to 50% width to achieve your desired layout.
If you do NOT need the default menu, you can remove it by unchecking the off canvas menu option at appearance > menus.
Got it, now i need to make the menu full height of the screen and there is a blue selection coming on the hamburger icon while tapping.
Add this as well:
nav#generate-slideout-menu .inside-navigation.grid-container.grid-parent, nav#generate-slideout-menu .inside-navigation.grid-container.grid-parent > .gb-container { height: 100%; }
