sargranger
how do I create an author block that will automatically appear on the bottom of each post? This will give the information about the particular author that wrote that post as well as an image of the person. thanks.
Hi Sargranger,
Here’s a video you may refer to regarding this: https://www.youtube.com/watch?v=4x6CjGOyagc
sargranger
Thank you. I went through the video step by step and created the author block element using a block-hook as shown exactly. I have two questions:
1. How can I add an avitar to each author? I don’t have a spot for one under the user dashboard in the wpadmin.
2. How can I get the author box to appear on each post. I have specified the location as POST like the video shows, but there’s something keeping it from being visible on each post.
Thank you again.
1. There’s a “Profile Picture” in users. The image should be coming from Gravatar. You can also add a custom Image field if you want. A plugin like ACF may help with that.
2. It should be displayed to Post > All Posts. Is it not appearing to all posts with that setting?
sargranger
For #2…correct, I just double checked the setting and it’s displayed to POST>ALL POSTS for the location and is not appearing. What else can I do to make it work? Thank you.
At some point previously, we might have turned off the author boxes from displaying…we can’t remember for sure or where that was.
Can you check what is the hook you are using? Can you change the hook to
before_footer
to test? -
sargranger
Thanks. It still does not appear. Here are the settings we have. . .
For the block element, we’re using:
ELEMENT TYPE: HOOK
HOOK NAME: BEFORE_FOOTER
PRIORITY: 10DISPLAY RULES:
LOCATION, POST, ALL POSTS -
That’s strange.
Can you provide admin login so we can take a look at the backend?
sargranger
I’ve attached the login below. Thanks for any advice you can provide.
It’s because you’ve selected administrators as the user in the element, so it will only show to users that have admin roles.
Remove that user from the block element should fix the issue 🙂
https://www.screencast.com/t/sUQTQj8UT -
sargranger
We are still unable to resolve #1…populating a user image in the author box. We installed a plugin as suggested (USER PROFILE PHOTO plugin), but the image still doesn’t appear in the author box. Would you be willing to look at it and let us know what we can do to make it work? (admin login attached))
Thank you.
I’m not familiar with this plugin, so I don’t really know how it works. But I do notice that you’ve disabled the author avatar display at settings > discussion > Avatars, try activating that option, and see if the plugin works 🙂
sargranger
That did it! Thank you.
