hello.
I am using the generatepress theme so well.
I’m happy with the optimisation, performance, accessibility and recommendations.
I have no desire to switch to any other theme because of this theme.
I would like to ask you something.
I would like to remove the category, title and date from the attached image link and make only the photo visible and clickable, how can I do this?
Thank you. -
It looks like you are using the Newsroom template from our site library:
https://gpsites.co/newsroom/So that section can be edited in Dashboard > Appearance > Elements > Home Post Grid.
Then you can remove the entire container that’s holding the dynamic List of terms, Post title and Post date:
https://www.screencast.com/t/bw1lVljgxhLet me know if this helps 🙂
Thank you for your kind reply.
I would like to delete the container, leaving only the picture, and then make the picture clickable as a link to the post.
How can I do this?
Thank you! -
The image is the background image.
However, if you want to use image instead, select the Post template block, and disable its dynamic data.
https://app.screencast.com/GMuM7qvDCgTzoThen add a GB image block in the Post template block, enable its dynamic data, set the image source to Featured image, dynamic link to single post.
https://app.screencast.com/LRz2KGV8RX9SLSet the image’s width and height to 100% so it can fill the entire container.
Thank you for the detailed instructions!
Everything appears to be set up correctly, and it should work perfectly as described.
Thank you! -
Glad to hear that 🙂
