hws991215
`add_filter(
that snippet requires you to add the
cu-limit-text
class to the Headline block. -
hws991215
<– Ok. please check.
ADDITIONAL CSS CLASS(ES) <– I put it here, but it does not apply.
hws991215
<– And I want this to apply to posts in the category tab as well.
<– Site shown in screenshot
It needs to be added to the ADDITIONAL CSS CLASS(ES).
Can you add it there?
If it still doesn’t work then it is probably related to the Character types. -
hws991215
I added it, but it doesn’t work. You can add it yourself and check it. Please check.
hws991215
It wasn’t applied because I didn’t press enter. It works fine now.
g <– Site shown in screenshot
You needed to clear the WP Rocket caches.
I suggest that your disable WP Rocket while you’re developing your site. -
hws991215
<– Site shown in screenshot..
It is the same process.
edit the query loop, select the Headline block and in ADDITIONAL CSS CLASS(ES). add:cu-limit-text
hws991215
thank you. I solved it.
Glad to hear that
