rayherb
how to make a sticky header without plugin,i want sticky header not sticky nav menu.
looking forward to ur rely.
tks!
can i see your site with the header you want to make sticky ?
rayherb
now my website is:https://goecofashion.com
i want to imitate the sticky header like:https://www.aungcrown.com -
There is a built-in feature in GP Premium to create that sticky header. You can refer to the documentation here: https://docs.generatepress.com/article/sticky-navigation/
rayherb
but when i scroll down,the nave menu will float left,i want to keep it at the same position,can u tell me how to do it?
for the best transition between the standard and the sticky navigation is to:
1. in Customizer > Layout > Header and activate the Navigation as Header option.
2. then enable the Sticky Navigation.It does meant the header will be slightly narrow, more like the example you provided, which can be increased with some CSS if you require. But what it will do is maintain the same nav layout and position in both states.
rayherb
how to set the height of header if i customize the header as you said above?
