AlexCCC
Hi, I am using NEWSROOM template, could you tell me how to make featured image clickable on homepage or sidebar post? Thank you.
if you edit the
Home post grid
element in Appearance > Elements.
And edit the Query Loop blocks ( there are a few ), inside them is a Post Template block, select those and set the Dynamic Data > Links Source ( GB Pro option ) – see here:https://app.screencast.com/AXsaEzIn5ybFN
You can then edit the
Sidebar - Home & blog
elementPro tip: When viewing a page, the Admin bar > elements menu will display shortcuts to any GP Elements on that page.
AlexCCC
Hi David,
As I follow your guidance and turned on Dynamic Data, but I cann’t see LINK SOURCE under BACKGROUND IMAGE SOURCE, what should I do?
Thanks. -
Make sure you’ve selected the Post template container block, then go to the dynamic data panel, choose the link source.
AlexCCC
Hi Ying, there is no LINK SOURCE, please check the attachment image.
https://i.postimg.cc/Mp4bYWM6/screenshot.png -
Hi Alex,
To clarify, do you have GenerateBlocks Pro plugin activated for this website?
AlexCCC
Hi Fernando,
Sorry for my mistake, When I activated the GenerateBlocks Pro plugin, it worked.
Thank you very much. -
You’re welcome, Alex!
