Anonymous
Hello! Trying to create a section on my homepage that shows 3 of the latest blog articles. Here’s a the layout I’m going for, but the posts are stacking vertically instead of horizontally. Any suggestions? Thanks!
You are using WP latest posts block, we do not have control over the core blocks.
Can you try using GB’s query loop block instead?
https://docs.generateblocks.com/article/query-loop-overview/ -
Anonymous
That helps, thanks! I get stuck at the next part though, and am still not sure how to achieve the layout I’m looking for. Here’s a video
Select the post template block of the query loop, you can set its
width
to 33.33% to have 3 columns, 25% for 4 columns, and 20% for 5 columns 🙂 -
Anonymous
That worked, thank you! I was able to figure out the rest from there, except this piece: is there a way to add a “read more” link after the excerpt?
Select the headline that represents the excerpt, you can either enable the
Use default more link
option or use a custom read more link:
https://app.screencast.com/jqhMjgyn5VVcQ -
Anonymous
Thank you!
No Problem 🙂
