daveporter
Hi everyone,
I have a site that has lots of documents to access.
I’m using the query block to display them.
I noticed that the gap between the rows is defaulting to 20px.gb-grid-wrapper-c9bb1323 { row-gap: 20px; }
But that is specifically for one grid wrapper, how can I make the gap reduced globally ?
I need to make the row-gap: 10px or smaller globally!
TIA, Dave
ps – example page linked below! -
Hi Dave,
There is a filter to set the default gap for the Grid block but unfortunately, this will only apply to blocks added afterward. The current blocks will not be affected.
In this situation, I think you’ll have to create a single global class to set the row gap to 10px or something similar, and then add the class to every block that needs this value in the Advanced > Additional Class(es) field.
daveporter
OK, might be best to wait for the full release of 1.7 & 1.9 ?
And if I did try it now what CSS is required to set it for that class ?
Thanks for getting back!
Dave -
You can add this CSS to customizer:
.global-gb-grid-wrapper-gap { row-gap: 10px; }
Next, select the Grid block where you want to apply this gap setting. In the block editor, go to the Advanced tab in the block settings and add the class
to the ADDITIONAL CLASS(ES) field. -
daveporter
Great, thanks so much!
Dave -
You’re welcome!
