Image Block Global Style – Not Reflecting Padding & Margin Settings
  • I am trying to create a global style for an image block. Everything seems to work except padding and margin. When I apply the global style to an image element, I see the padding and margin settings in the editor, but on the front end it doesn’t seem to apply the padding and margins of the global style.
    What can I do to fix this?
    When something works in the backend but not frontend, it’s usually a caching issue.
    Can you make sure all plugin cache and server cache are cleared first?
    If you could provide a link to your site where this issue is happening, that would be helpful too.
