I recently added the InBound template to my website, NoHate.se. It works well for visitors, but the site editor is very laggy. Every time I click or try to edit something, everything freezes for a few hundred milliseconds. This makes the editor difficult to use. Can someone please help me understand why this is happening? I want to continue using this template.
Any specific page I should be checking? I checked about and homepage’s editor, I didn’t see the lagging issue.
Strangely, when I logged in using Incognito mode, it worked quite well. Although there is still some lag, it is substantially improved. Do you not notice any lag at all? Try editing the page called “Home” and change some headings. When I do that it freezes for a small moment.
No, not at all.
If the incognito window works fine, I guess the issue would be related to browser extensions/cache/cookies stuff.
I suppose so! I tried deactivating some unimportant extensions and clearing cache but it is still lagging. I have never had this problem with GeneratePress before. Guess I will work with the website in incognito mode then. Thank you for your help!
No problem!
