usethebitcoin
Is it possible to make the archives set to infinite scroll?
Thank you
I thought I’ve answered a similar question of yours before, here’s my answer from that topic:https://generate.support/topic/loop-template-dynamic-load-more-button/#post-97698
usethebitcoin
Hi Ying
Thank you for responding but have you seen the example website? and then ours? the infinite is not working even though it was set in the Customize so I am asking.
There isn’t an infinite scroll option for static pages, the author page you provided does not have an
archive
class in the body.So is it a static page or an author archive?
usethebitcoin
It’s for archives instead of having pagination or load more button, is there any options when you scroll it will load the other articles.
as I said, this is the
infinite scroll
, it only works on archive pages, and it does NOT work on query loop blocks. you will need to create block element – content template instead of block element – loop template for it to work.The option is at customizer > layout > blog.
I hope it’s clear!
usethebitcoin
Thanks Ying for this.
No Problem 🙂
