I have bought the GP to see nice get up of INFO THEME, now, how to make it, is it automatic or I have to know a lot of things. May I know how to proceed.
It is a bit urgent as I have made my site a mess ;d
Hello Firan,
You need to manually set the Parameters you prefer and you should be all set.
1. Click on the Query Loop block from the List view.
2. Then click Add Parameter:
https://docs.generateblocks.com/article/query-loop-overview/#query-parameters3. Select Taxonomies from the query parameter drop-down list.
4. Then select Categories or Tags.
thank you, let me try,.. have to learn… I have to buy generateblock as well?
Is there any tutorial, as i dont have that much of knowledge
GenerateBlocks Free is already installed with that site.
See my reply here:
https://generate.support/topic/category-edit/#post-3230
If you’re still stuck then let me know.
Is there any specific theme as info theme, I have only installed Generatepress plugin,and theme, not installed any specific name as INFO THEME
I’m not sure I understand. To clarify, are you referring to this Info template?: https://gpsites.co/info/
exactly this template, where from I will get it
It can be viewed from the Site Library. On your admin dashboard, go to Appearance > GeneratePress > Site Library. More information here: https://docs.generatepress.com/article/using-the-site-library/
uNDERSTOOD, LET ME FIND OUT, IT IS AN EXISTING SITE, WILL be any problem, i dont know the meaning of stagging site, any additional thing to do for that, or simply I can use that template
Can we see your site ? Then we can get a better understanding of the issue
