Issues with Smooth Scroll
    I am creating a new site with GP + GB.
    And for some reason, the smooth scroll on the links is not working.
    On the buttons it works fine.
    But the links are not.
    This is the URL: https://v2.littlemouseproductions.com/
    Here is a demo: https://take.ms/ZEgxv
    Can you please help me?
    Thank you!
    When a custom class is added to the headline block, it adds to the <p> tag instead of the <a> tag:
    https://www.screencast.com/t/DufWhUX1JX
    For the smooth scroll to work, the class must be attached to the <a> tag.
    Can you replace the 4 menu links built with the Headline block to use the Button block instead?
    Or simply use the default header and menu system.
