I have a sticky header, all good.
I would like to put a bar of text underneath the navigation menu items.
I have used generate_after_primary_menu, and this has put the item at the end of the menu items, rather than a new row underneath. this row will link to a contact us page and have some other contact info. I would like this as a persistent row under the menus. I’d also like to add the same thing above the menu, in the sticky header. Thanks! -
can you share a link to your site? Then i can assess the best place to make those changes.
deer.management/staging
Thanks so much for the help.
Can you try setting the GB container holding the BOOK headline block to
width: 100%
https://docs.generateblocks.com/article/sizing-options-overview/Let me know 🙂
Hi, thanks – yes, that made the control span the 100% of the menu width. I was hoping to make the control span the whole width of the header / container, like a banner. Thx so much!
Then you need to use
after_header
hook.And change the
top
value to70px
in the below CSS:.sticky-header { position: -webkit-sticky; position: sticky; top: 0; z-index: 1000; width: 100%; }
Brillaint – thanks so Much!
Ah, so there is now a side effect whereby the new bar position is now over the menu generation, so the menus now appear under the bar, presume there is maybe a Z setting for the menu?
Thanks so much for all the help – this is my first day with generate press.
the
top
property sets the top position of the sticky header.
Change the CSS to this:.sticky-header { position: -webkit-sticky; position: sticky; top: 70px; z-index: 1000; width: 100%; } @media(max-width: 768px) { .sticky-header { top: 80px; } }
On desktop its set the top position to 70px to offset the sticky nav position. And it increases it to 80px for the taller mobile header .
