ledinhtan
I tested my site with Pagespeed Insights and received this error:
Avoid large layout shifts 3 elements found.
I used Smush Pro and Litespeed Cache. I disabled lazy-load on both and all CSS settings in Litespeed Cache, but I still encountered the error.
What could I do now to solve this? -
see here:
https://app.screencast.com/Br2AFheEgSxCl
Your logo is being lazy loaded, and the lazy loader is using a Square Placeholder Image, which is terrible and the developer really should fix that, as what happens is the browser saves too tall a space for the actual image.
You should report that issue to the lazy loader developer.
In the meant time check the lazy loader settings, they generally provide a field to exclude images with a specific CSS Class use:
is-logo-image
ledinhtan
Thanks, David. I have successfully resolved the issue with the logo. However, Google continues to display this message. How to solve these?
It’s still the logo causing that CLS.
It seems to still be lazy-loaded with a square placeholder showing while the image is being loaded.
Could you double check if where really able to exclude the logo from that feature?
ledinhtan
I have checked and removed the lazy-load of the logo from Litespeed Cache. You can see here.
I also disabled lazy-load on Smush Pro and WordPress core.
Can you help me check more closely what the cause is? You can access the website with private information. -
I’m not getting any CLS anymore: https://share.zight.com/7Kun6EJK – this just confirms that the issue is from the optimization(lazy-loading) – could you try retesting?
ledinhtan
Yes, all is good. Thanks, Fernando. Could you tell me what you did to get that result?
ledinhtan
I thought everything was fine but now when I test it again it still has the same error. Can you check again for me?
I didn’t do anything. I just tested again with your setup where the logo isn’t lazy-loaded.
I can see that you’ve activated lazy-loading again, and the logo is again lazy-loaded which caused the CLS issue again.
As mentioned, you need to ensure that the logo isn’t lazy-loaded.
ledinhtan
How can I check if lazy-loading is disabled on the logo? Because I turned off all other lazy loading features, leaving only Litespeed cache.
If you Right Click > Inspect the logo, and check the HTML in the browser dev tools you will see this:
https://app.screencast.com/NrLoVeRghczWW
There is the
data-
attribute that the lazy loader uses to store the image URL
And thelazyloaded
class that gets added once the lazy loader had loaded it.I also see in the HTML comments ( after the footer ) that the site us running a Hummingbird cache….
ledinhtan
Thanks, David. I completely deleted Hummingbird Cache and everything is fine now.
Glad to hear that!
