Largest Contentful Paint
  • I seem to be having an issue with my LCP, and i’m trying to make sure my featured image isn’t being lazy loaded so I’ve added it as an exclusion in perfmatters (screenshot added). Have I got the right class to avoid the main image on my posts being lazy loaded?
    Thanks in advance.
  • I’m not sure if the exclude rules should be filled like that, I would recommend checking with the cache plugin’s support.
    Your featured images are optimized by an image plugin, it seems to be adding no-lazy class to the image, so you can target the no-lazy class.
    As far as i can see, the image is NOT being lazy loaded.
