I am learning GB and shifting my sites to it and any new sites. Once I get this it will be a game changer.I am having an issue on a block I am trying to make.
I have it at this urls https://inksplotweb.com/learning-gb/
The section is all in one top level container.
The top header is in the correct place.
The next 2 containers are not centering on the page.
What other information do you need in order to help me?Thank you
Janet -
Hi Janet,
Sorry I don’t understand the issue you are having.
When I check the page, everything is displaying in the way you’ve set it up:
https://www.screencast.com/t/mao6ay1ejg8What is the exact issue you are having?
When I put this in I hadn’t messed up the site royally, which I just put in a new ticket for.
But the three headlines under the headline that is in the right place, isn’t centered.The bigger issue now is I reset the modules and now the site has lost all it’s colors and set up.
Sorry I don’t understand this statement at all.
I’m not seeing any settings being chosen that suggested the headings should be centered.
Do you have a mockup or example of the desired layout you are trying to create?
A mock up Hmm
Headline
Headline Headline
Paragraph paragraph
HeadlineSO the headline/paragraph block and the bottom headline block is centered under the top headline block.
Does this help?
THank you -
Do you have an actual example to help me visualize?
I don’t. Thanks fro trying.
Thank you -
No problem 🙂
Just post here again when you have an example to show and we will be happy to guide you through.
