Anonymous
I created this new page “Services” and the block that I put in doesn’t left align with the header.
Can you please show me which setting I should change? I changed the alignment settings and still can’t seem to make it go.Thank you.
select the Cover Block and in its block toolbar uncheck the Wide Alignment option.
Anonymous
Thanks, David! It looks a lot better but there is still some left side padding on the cover block that I can’t find the setting for…
Please have a look here: https://staging.magnuslu.com/wp/services/
The cover block has a 1em padding around it by default, as the cover block is not from us, we don’t have control over it. I’m not sure if it has a setting to change that as well.
If you can’t find that setting, try adding this CSS to override the default cover block style.
.wp-block-cover, .wp-block-cover-image { padding: 0; }
Anonymous
Thanks Ying.
Anonymous
Hello
I’m having the same problem on the same page but this time I just have a container of text and a button.
I don’t see the width controls here.
What is determining the width in this case? Basically I just want the content to be left justified with the logo, like on the other pages.Thanks,
Magnus -
Anonymous
Sorry, never mind! I changed the “Content Container” to default on the Page settings and it’s aligned now.
Glad you worked it out 🙂
